06-10-2006, 09:30 PM | #1 | ||
Hey everyone just wondering on how to adjust the hand brake on a au2
1 tonner. Cheers Craig |
06-10-2006, 09:45 PM | #2 | |||
hint hint GK
:eclipsee_ MY CAR :eclipsee_
06-10-2006, 11:39 PM | #3 | ||
on the inside of the rear discs, ie where the axle surround i guess joins the diff, on the back ie towards the centre of the car at the top i think, will be a little hole shaped for a flat head screwdriver, apparently its a pain to adjust, im not sure as i've never done it, but you twist a cog type thing in there to tension it, just make sure the park brake is off when you do it
07-10-2006, 12:33 PM | #4 | |||
Posts: n/a
I tried for that.It is well. I can do that. T han k you very much. |
07-10-2006, 04:25 PM | #5 | ||
Walking with God
OR
You could see how much adjustment is left in the 10mm nut at the handbrake lever. Just remove the boot, push the seat all the way back, take the handbrake off, and use a 10mm spanner or thin tube socket to adjust away. I would do that first, then if it's no improvement, adjust the rears. Cheers, GK
08-10-2006, 12:11 AM | #6 | ||
Thanx guys ill give it a go in the morning as im not to keen on the resting pressure on the parking pin at all aspecially having the trailer with lots of weight in it Thanks heaps.
08-10-2006, 09:37 AM | #7 | ||
Ripping it up
My handbrake is, and has been for 2 years, soft... repalced everything but the cable itself (and the lever that goes to the drums). Done discs, pads and rotors, and only a marginal improvement... (it actually engages now)
08-10-2006, 09:52 AM | #8 | |||
buckled rim finder
08-10-2006, 10:01 AM | #9 | ||
TL40 Wagon?
They are a pretty average design and parking brake is about all they are up to.
You can adjust the cable to take up the cable stretch at the handbrake end but this does little for effectiveness of the handbrake. You can adjust the handbrake shoe to drum clearance with an adjuster wheel through an inspection port and this does work. But. . .. go too far and you get annoying noise from it dragging at low parking speeds as the shoes don't centralise well when released. By the way discs pads rotors have nothing to do with the handbrake. Its a drum brake inside the rear rotor. |
08-10-2006, 10:42 AM | #10 | |||
Walking with God
GK
09-10-2006, 04:52 PM | #11 | ||
Ripping it up
I know the pads have nothing to do with it, but still... the drums sit inside the discs... Theyre floating discs.
09-10-2006, 04:58 PM | #12 | |||
TL40 Wagon?
Exactly why if you adjust them up nicely they squeak at low speeds in car parks etc. Annoying but you may prefer to have a handbrake that works. |
09-10-2006, 08:03 PM | #13 | |||
Walking with God
GK
09-10-2006, 09:57 PM | #14 | ||
Fantastic Plastic
Just my 2 cents , when adjusting the handbrake on any car really / there all pretty much the same setup ....
I just apply the handbrake 3/4 way inside the car, then adjust the handbrake via the hole in the hub of the disc (behind the screw in the hub) using a flathead screwdriver to wind/adjust the wormgear until its just firm ( until the pads of the handbrake are just touching/applyed ) . Using this method , and i did this on my auii aswell , the handbrake work fine , without any /rubbing/dragging/squeeling while driving. cheers.
------------------------------------------------------------ :eclipsee_ |
10-10-2006, 03:48 PM | #15 | |||
AULTD
I remember when I bought my Ford the handbrake wasn't holding so I complained about it to the car yard ( non Ford ) as it had just been roadworthied and supposedly passed. The salesman told me the handbrakes don't work too well because the V8 is so powerful its hard to hold!!!! My reply was even with the motor not running the handbrake won't hold the car. Needless to say they paid to have it adjusted. It just goes to show salesman will say anything and if you don't know about these things you get taken for a sucker. |
