#1171 | |||
2016 Mazda 3 SP25 GT 2019 Hyundai i30 Active. |
#1172 | ||
I have been looking everywhere. Does anyone know What amperage the new Ranger V6 diesel and the Ranger Raptor V6 Alternators are please?
The FX4Max on the last ranger started to use high output 250amp alternators. Which was great if you are running high draw lights, Winch, Fridge and charging a dual battery setup etc. Have they carried over the high output alternators? Thanks |
#1173 | |||
Fordless Stuff this,I'm going to play a few shots & see what happens. |
#1174 | ||
2 users like this post: |
#1175 | |||
Where is this information about driving it around with codes?
#1176 | |||
250 amps, 110 amps at 625 RPM (min) to 250 amps at 2500 rpm (max) for V6 Raptor. |
3 users like this post: |
#1177 | ||
Thailand Specials
That is impressive, they've obviously thought about uses here for the Ranger, being able to pump out 145A continuously at idle is a game changer for maintaining big battery banks and having decent electrical accessories.
#1178 | ||
In a way, yes unless you accept the “moron’s defense”.
Even after after after days of fault codes coming up on the dash, he chose not to return it to the dealership or even look under the bonnet, had he done that he would have noticed the loose battery cables that nearly killed him. |
#1179 | ||
#1180 | |||
#1181 | ||
Wouldn’t that charging rate be hard on the battery(s)
#1182 | ||
#1183 | |||
loose battery cables, anything that happens beyond that is all on Ford. It just suddenly burst into flames. Once that happens, people’s lives are endangered, and anything before is of no consequence. The fortunate thing here is that internal testing proved that it was down to loose battery cables, they know exactly what was done and how long to failure and fire occurring, so an unnecessary recall was avoided……beyond that, no allegations were made by Ford. Last edited by jpd80; 26-07-2022 at 09:46 AM. |
#1184 | ||
Peter Car
#1185 | ||
#1186 | ||
Can someone explain in laymans language what the advantages and disadvantages of smart alternators.Cars seem to have been working for the last 50-60 years without a smart alternators,so why the change?
#1187 | |||
Thailand Specials
You can leave it on as long as you earth the auxiliary batteries to the chassis of the vehicle, this worked with basic dual battery setups on PX and PXII - they have a sensor in the negative lead on the starting battery that the smart charging system uses, if you try earth the auxiliary batteries to the negative terminal on the start battery they don't charge properly. Last edited by Franco Cozzo; 26-07-2022 at 07:37 PM. |
#1188 | ||
Thailand Specials
Something I don't like about that big screen is how laggy the interface is - look at when he goes to move the GPS screen around and how jerky it is, same as moving between functions and even using the sketch app it takes ages to register what he's doing on the screen. Its real obvious at 13:43 where he's moving the GPS around and the map becomes real jerky on the zoom out/movement/zoom in and navigating around the map, looks like the framerate is 10-15 FPS, its an absolute slide show with how jerky the interfaces are when moving around screens. At 16:52 you can see how badly it handles that 'sketch' program, the delay between what he's touching on the screen and it actually appearing in the program makes it feel like they've really undercooked the hardware that is driving SYNC, or its just very bloated. Navigating to the vehicle settings at 17:08 it takes a good half to 3/4 second to go from button press to actually opening the menu and the transitions between menu options is jerky, if you could disable the menu transitions I think that would be a good way to reduce how aggravating that is to operate. Even opening other menus it takes half a second or so to display text which fills in on the screen rather than display it instantly, I'm hoping those are transitions rather than limitations. I really wish auto manufacturers would just give up on trying to make their own infotainment systems like SYNC and just subcontract out the hardware and software side to Google/Apple or other SoC manufacturers to do all that functionality and use what everyones phone does. I've got a phone thats a couple years old running Android 11 that cost $250 when I bought it new, years later and a billion software updates it still responds instantly to your inputs with the transitions between screens happening smoothly and manipulating Google Maps isn't laggy or behave like a powerpoint presentation. I do like that they've given you all the HVAC and volume controls as physical buttons, I'd be using those rather than the screen for those functions. I'm curious as to the specs of the hardware thats driving that SYNC infotainment system. I really like all those features it has but I don't like the implementation - kypez how does the Tesla implementation of its infotainment screen operate? Last edited by Franco Cozzo; 27-07-2022 at 02:10 AM. |
#1189 | |||
turning the battery into kind of like a capacitor to prevent voltage spikes hurting electronic components. Modern charging systems have moved beyond doing that. |
#1190 | |||
Rest of the interior (and car as a whole including the drive) was bloody awesome and I cant wait for mine... Was even stoked to see my colour in the flesh also...
2008 FG XR6 Turbo ZF In Sensation - Gone, but not Forgotten.... Hers: 2024 Ford Everest Platinum in Equinox Bronze His Daily: 2020 (MY21) Kia Sorento GT-Line in Mineral Blue His Weekender: 2017 Commodore SSV Redline manual in Light My Fire Orange |
#1191 | |||
Similar to drive by wire and electric hand brakes....which IMO all have substantial negatives to them , all of them were fixing something that wasn't broken .
Fgx xr8 winter white manual, gone but not forgotten 22 mitsubishi outlander XLS PHEV Au11 fairmont Ghia ported gt40p heads ,comp springs and locks Xe 264 cam,custom intake,pacemaker tri y headers 524nm torque 19 Triton GSXR manual |
#1192 | |||
A mate was telling me they had the smart system disabled by the dealer on their Rangers. They were getting flat batteries when they left the yellow flashing light running when working on site. |
#1193 | ||
Peter Car
Drive by wire has a heap of advantages over cable throttle though. Emissions reductions are the main reason it was implemented. Driver assist systems compatibility the other.
#1194 | |||
Peter Car
Ford is the latest automaker to turn its vehicle operating systems over to Google. The Dearborn, Michigan-based company said it will use Google’s Android to power the infotainment systems in “millions” of its cars starting in 2023. That means Google’s voice-activated Assistant, Google Maps, and other automotive-approved Android apps will be available in Ford’s cars without requiring the use of an Android smartphone. |
#1195 | |||
Thailand Specials
![]() Unfortunately it's a symptom of engineers having to design a car that suits 200,000 people's driving styles so you end up with a compromise. I particularly dislike how the DBW throttle operates on VF Commodore it's absolutely horrible with a huge dead zone and delay to minor throttle inputs but it can be improved markedly if you're that way inclined. I'm pretty sure it was used in the FPV GS to only give it 315KW - 100% pedal didn't equal throttle plate open 100% it would only open the throttle plate at a maximum angle rather than all the way. Last edited by Franco Cozzo; 27-07-2022 at 11:56 AM. |
#1196 | ||
We had to d/c the smart charge on the mine spec Rangers we got in 2015 due to flat batteries all the time also
FGII FPV F6 #406 BFII FPV F6 Typhoon R Spec #118 VK HDT Group A/Group 3 #3249 |
#1197 | ||
Yep and a major negative called driveability
#1198 | |||
#1199 | |||
Thailand Specials
If you get a car remapped you can control all of these things, you can have it just like a DBC setup where what you do with the pedal is what it does at the throttle body with all the benefits that DBW brings. The issues you're talking about is how the manufacturer wants the car to behave, the factory implementation of the DBW setup on the WZ Fiesta ST is mint, it's a manual car and the throttle response is crisp both on and off the throttle and that's a factory setup. It's all modifiable through a remap if you want to change how the throttle behaves, the little external box is a band-aid slap on. Last edited by Franco Cozzo; 27-07-2022 at 12:55 PM. |
#1200 | ||
Rob
I would imagine the lack of physical cable improves nvh as well?
UA2 TREND 4WD BI TURBO |
Thread Tools | |
Display Modes | |
