04-11-2023, 08:49 PM | #1 | ||
Diesel Motor
Hello,
My car is a 2011 Ford Focus TDCi. Does the brakes on this car have to be bled by a diagnostic tool, or is it ok to just use a brake bleeder vacuum pump? Thanks, Radioactivex |
04-11-2023, 09:19 PM | #2 | ||
Hi. sucking the brake fluid out is always risky as all the seals in a brake system are designed to hold pressure in. Unless you get air in the system you wont need a diagnostic tool to bleed the brakes. Just do it the old fashioned way and pump out most of the fluid from the master cyl, top it up and repeat a few times for each wheel. Cheers MD
04-11-2023, 11:35 PM | #3 | ||||
Regular...with metamusal
use a say 'horse' syringe [large type] to empty the master cylinder 1st & then top it up with fresh [which is what i did with my BA. got syringe from a place called "pet stock"], then follow what is mentioned below. Quote:
