growing up is optional
Easiest way to check the fan is to unplug the thermo switch near the distributor. It will have a single wire going to it. The fan should run with the wire disconnected and the ignition on.
If it doesnt, you will have to look further for a wiring or fan motor fault. If it does, the wiring is fine and the thermo switch is stuffed. |
